Bad mid-range driver (speaker)?
One of my mids seems to have gone bad, certain songs have a sustained frequency that causes harsh distortion out of one of the passenger rear mid range speakers. Are they all interchangeable? The parts numbers might be different due to different mounting bracket configuration, so the reason I'm asking is that I ought to be able to swap out just the 4" driver from one mounted in a bracket intended for a different location in the car.
Thanks
Thanks
One of you must know...
Maybe I stated it too technically (I used to manage a high-end audio store)
Each mid-range/tweeter assembly contains one tweeter and one mid-range. The bracket holding them might be different for each location, but the tweeters and mid-ranges can be removed from their bracket. What I'm asking is, once removed from the location-specific bracket, are they all the same?
Before you replace that driver, are you sure this isnt a resonance vibration from your door panel? I was convinced my passenger door driver was hooped but it turned out to be a loose piece behind the panel
Yes, your advice is correct. I have downloaded a tone generator app onto my smartphone, which I can hook up to the car stereo through the aux cable and hopefully find a frequency that will excite this distortion/vibration. Then I can determine, with a stethoscope if necessary, exactly which driver is making the noise and whether it's coming from the driver itself or from some nearby car trim or a particle of something trapped inside the driver mesh cover.
Getting ready to move cross-country (California to Florida) in this car next week, excited and worried. I have replaced the battery, the (failing) HID bulbs, and will be doing the water pump, coolant and oil this Saturday in advance of departure 7 days later. I've just bought the car and it has 114,000 miles on it, hence the precautions. The speaker issue is therefore of secondary importance because very few songs have any content that causes this effect.
Bob Graham
Bob Graham
anesthesia
08-20-13 09:22 AM
lowKut
25
05-11-09 07:30 PM
kit cat
17
05-05-07 10:36 PM
