Considering a 460 or 460L, ~$40 k, thoughts?
10th Gear
I have about $40,000 i'd like to buy a used LS460 or 460L. I currently have an ES350 (which I will keep), so I know Lexus well.
I want input on:
Which model year(s) are most reliable. What option(s) to look for/avoid (I hear the AWD can be problematic??)
For those of you that have the "L", does the extra space justify cost?
I want a daily driver (short work commute), but something that's great for family vacations. I'd love to get the 2018, but too much $$.
Thoughts?
I want input on:
Thoughts?
Your def in 2013-2014 range. I like my L but one of the reason I moved down in years is because after I came to MY senses I knew the 10k premium for the L version just was not a wise financial decision for ME. The space is a huge upgrade though so if thats high on your list go for it.
For me the L is all about the looks and the presence it has on the road. the 5-6 inches in the backseat really isnt going to do anything except add a little bit of leg room for adults sitting in the back.
It is also quite rare which makes it more desirable in my opinion.
I have air suspension on mine, and the ride is nice but be prepared to either spend money on it once in a while, or swap it out for struts and springs when it acts up.
Id definitely stay away from awd, as you not only lose power but also lose any aftermarket support for control arms and anything suspension related.
You do pay a premium for the L but you will also get that premium back when you re-sell it, so to me its worth it.
If you want a 460 I really wouldn't get too focused on the little details, as u will be waiting forever to find the right one and then u will end up missing out on lots of deals that could of been had.
I bought mine with the air suspension and without mark levinson system, which is the opposite of what I wanted , but the price was right so I took it. Id rather that then spending $10 000 more for my ideal car with the perfect options.
sha4000 (12-30-17)
I am in Canada and all the LS since 2013 are AWD here. I am in the similar situation looking for a 2013.
The main options I would like to have is the blind spot monitor, cross traffic alert and ML system.
If you want the reclined back seat and cooler, it will not offer the trunk access for longer item like ski or some 2 by 4s for small project.
If the extra space is really important, then go for it. My problem is my grage will be too tight after parking the L. I want some extra space between the wall and the rear of the car.
If you want the F sports then it does not have the recline and cool rear seats option. And I do not see any 2013 F sports with blind spot and cross traffic alert so far.
Good luck to your hunting.
I wouldn't be concerned with getting an awd model unless you really need it, the rwd is a little lighter, quicker, better fuel economy and more horse power. I live in an area where it snows all the time and I've done just fine with my rwd model with snow tires.
10th Gear
Thanks for the great input. To summarize what I am hearing:
1. The "L" is nice if needed, brings with it a steeper price, but makes it a standout among other 460s. Expect to add $5-8k for this.
2. Avoid AWD (unless needed, which in Atlanta, I don't)
3. Avoid air suspension or pay to switch/maintain down the road.
4. ML Audio is worthwhile
5. Don't seek perfection in your search. List "Must haves" and "Nice to haves" and then get it!
I miss anything?
I miss anything?
I miss anything?
I miss anything?
With that budget, you may want to pinpoint the 2014 base model with the ML system. I prefer RWD, but your mileage may vary. The L is great should you need 5 extra inches and if it fits nicely in your garage.
I miss anything?
I miss anything?
Remember to check the upper control arms or have them checked and don't use the dealership to replace them, go with aftermarket parts and a independent to save a ton of money or do it yourself.
ML is pretty rare on LS's
In the states I would say maybe 1 out of 6 or 7 LS's have ML from my search over the months, maybe even less then that. Canada might be different as your cars may be higher spec like more AWD, etc. Canada often gets some nicer options or standard features on vehicles then the states like head light washers on GS's, real wood trim on Acura MDX's, etc.
The newer the cars get the rarer ML gets. In my experience on a 13-17 car finding ML on a SWB car is pretty rare, most cars are optioned like my 2015, no semi aniline, no ML. LWB cars all seem to have ML and semi-aniline, AWD means no air, air means no AWD.
The LWB car rides a little better than the SWB car, and as ***** said, it looks more imposing on the road.
I miss anything?
I miss anything?
This one is out of my price range, it is a loaded Ultra Luxury 2012 L with the rare Executive seating package, one owner, clean carfax, 48K miles. It has air suspension but figured I would share it, I am sure there are a few who are looking for one like this.
