high height
Former Sponsor
Kelly - The engine will shut off while in motion. I've done it and posted about it on here (and caught some flack about it). You just have to hold down on the Start/Stop, for I don't know, maybe 5 seconds.
Jason
Jason
mckellyb (01-29-18)
When I get mine back from the shop (this week) I'll grab some video of the Air Controller showing the suspension lowering above 65 and raising again once below 60.
I do admit there is very little body roll on my car, but I have not heard its active until now
Going to do a little more research on it, because usually if its active the car would have high pressure pumps or hydraulics to keep everything adjusting in real time, and I don't think we have that
I didn't know we had active body control , and if so that makes me less interested in swapping out to a coil/spring set up.
Tangentially-related; there is body roll, eventually, as I found when hooning my LS around the nearby traffic circle and around the other two small ones on the way to work every day.
My last front tires were both feathered, outside-to-inside, from pretty much maximum daily aggression. The car can handle it, no problem, and I find it's actually more enjoyable near the limit than my STS was, and the STS was sold as a sport sedan!
The STS, as I owned it, could pull 0.86 on a skidpad (as driven by professionals), the LS with Sport goodies, 0.81. I honestly don't notice a difference in cornering grip, other than the LS has yet to 'bite' me. The STS did...a couple of times.
The LS is larger, much comfier, heavier, and lots of other things, yet it's quicker, gets better MPG, and IMO, handles better.
I've had more than a few "really?!" moments over the last 15 months, from being truly surprised any auto manufacturer could combine the qualities of this one, all in the same car.
Yeah...I set mine to the maximum, 0.8", so my 'height high' would be maxed out.
I want to say it was 0.5" when I started, but I can't find a screen capture for it.
Why didn't I think of just hooking up the Fakestream and recording what it does?! /facepalm
I'd totally forgotten Techstream has a built-in recorder for data.
I'll have to do that next time I know I'll be on a freeway. Ooooh! I just thought of something I need to do which does require a solid 7 minutes on the tollway. I'll update, later.
Nope, not active, though the air system can help things by at least partially shutting valves to keep higher pressure at any corners which need it. However, beefy anti-roll bars and a well-designed suspension do most of the work.
Returd
Performance & Maintenance
11-22-18 05:47 PM
