Best phone mount for the LS (merged threads)
#76
Please check out the thread link below. I posted a photo (post #8) of the low profile phone holder that has worked on a Note 5, S7 Edge, and now Note 8. It has never dropped the phone and also doesn't droop down or slant down from the weight of the phone.
https://www.clublexus.com/forums/ls-...or-the-ls.html
#77
Pro Clip phone mount?
In doing research for a good cell phone holder I see alot of LS460 owners have the pro clip attached to the center console. Can anyone tell me if when sitting in the passenger seat does it conflict with the legs of the passenger. Hard to tell from the photos.
thanks
thanks
#78
It does not. It interferes a bit with the right side radio **** on my 07, but not enough to make it impossible to use.Also, I didn't peel off the double stick tape, so while it stays in position under normal use it is easy to removes and store.
N3VR4G3T (07-16-18)
#79
Awesome. Thanks for the reply. I will be placing the order tonight.
#80
We use this one in the '14 and has worked out well.... It attaches onto the air vent blades.... Add a USB charger cable and you are all set... The phone is mounted horizontally in our usage....
#81
N3VR4G3T (07-17-18)
#83
I used the Pro Clip on the console and put a Ram Ball on it. Then a Ram Mount scissor type holder that I already had for my Triumph. Put a USB adapter in the lighter socket right behind it, with a retractable cord. Totally reversible and easy to pull everything off and store/transfer.
#84
Where do you guys keep your phone? any nice solutions
I had a small magnet mount but my iphone x keeps on falling. I got one of those gravity mounts and i hate the way they look, so bulky and ruins the dash. I cant stand anything stuck to the windshield. Alot of phone mounts go in the vents and i feel like every time i want to pull or adjust i would just break the vent.
i cant be the only one; what do you guys suggest that is low profile and does not stick out as much.
thanks!
thanks!
#85
thanks!
thanks!
#86
I used a Pro Clip mounted to the console paired with a Ram Ball and scissors style holder. Can remove everything easily, it mounts close to the power outlet. I can easily reach it, in view,and the setup feels solid and out of the way. I can remove the scissor holder easily and transfer it to the motorcycle Ram Ball. The Pro Clip does have double stick tape to keep it in place but I never peeled off the paper, as it stay put and that way a simple twist and you can throw it in the glove compartment. I stuck a usb double slot converter in the cigarette lighter with a retractable charge cable. I have an O7 that still has an ashtray. I pulled out the chrome ashtray piece, so opened up that space to hold the retractable cord, so can shut the door that covers the ashtray/lighter if not using the phone. So bone stock to great solution in about 90 seconds, completely reversible in less. Only slight issue is with phone in place it can eat up some space over the front cup holder, and taller drinks may not fit in the front one but no problem in the rear front cupholder. Can post a few pics later if you are interested.
#88
Hi Spudo,
Were the Ram ball and scissor holder from Proclip? Can you please post a pic and links to the products? Thanks!
#89
Any suggestions on a magnetic mount? On my LS430 I mounted one of those adhesive magnetic ball mounts (just below the navigation screen, on the L side of the trim) and it was in a perfect spot. Doesn't block the vents, good location when using for navigation, and magnetic mounts are just so convenient. Doesn't look like there's a good spot for a similar mount on the LS460 though, any recs? The Pro Clip looks OK, but trying to see if I can find anything better. Was thinking about one of these (), but it would just ruin the clean dash. Thoughts?
#90
I like my Scosche mag mount charger...very stable, super easy to mount/remove phone (steel plate in back of my phone case) and doesn't interfere that much with the cupholders (tall cups gt in the way a bit). You do have to buy a short USB cable separately if you want to charge your phone. And just by change the blue LED color is very close to the blue color of the car's display...Hope you can see the pics clearly...
