new exhaust mod from oliver
kingbabu (04-15-18)
#32
Standard Single Set:
- 35 mph cruising: You might hear a bit of rumble.
- 55 mph cruising: I doubt you will notice any additional sound.
- 75 mph cruising: The only time you will hear it is if you pull a hill and push the throttle down some, and then ... maybe you'll hear a little something.
Double Stack Set:
- 35 mph cruising: You'll hear a bit of rumble.
- 55 mph cruising: You may notice some sound, but nothing that would be ANYWHERE NEAR obnoxious. Nominal radio music will drowned it out.
- 75 mph cruising: You might be able to barely notice, but when you pull a hill and push the throttle down, you'll probably hear a little something, just so you'll know it's there. Radio again would drowned it out.
My above analysis is just from experience. It may not be exactly right because I never took notes under the above circumstances. But suffice it to say ... I have experienced zero instances where the sound was not welcome.
krypto - I will keep you (and the forums) aware, when they're available. It should be in 2 to 4 weeks. I'm actually running the "test sample" Stealth Vents on my car. Same sound, with "nothing to see here!"
The following 2 users liked this post by Oliver Enterprises:
jrmckinley (04-13-18),
Santa01 (10-04-20)
#33
Totally agree with poster above .I have the dual setup and it's not obnoxious whatsoever. He's 100% correct on his description. I was thinking about getting a custom exhaust and I'm so glad I didn't waste all that money for no reason. I'm satisfied and it's everything we describe it to be. Trust me you won't be disappointed. I'm able to talk on Bluetooth with no problem inside the car. No distraction at all.
#34
I have a single set on my '08. Nice rumble at idle and around town, absolutely no difference at highway speeds. You only hear the difference if you really hammer the gas.
Quiet at highway speed was a priority for me- these fit the bill.
kingbabu (04-15-18)
kingbabu (04-15-18)
#39
I must admit that it does sound pretty nice. The vents go in between the midpipes (after the cats) and the mufflers so I don't know what "illegal" gas the above dude is talking about.
I also bought a single stack from Jason a couple months ago. And I finally had the vents installed last week at the muffler shop (cost $60). I jacked the car up and attempted to DIY, but I gave up and didn't want to go underneath the car. Luckily, I had the shop did the work since one of the bolts was seized and broke off.
When I told the muffler guy what I needed done, he said why don't you just drill a hole in the muffler instead. I told him umm no.
I should have gone with double-stack because of the ricer in me. I want to it louder!
#40
TIP!!! Before installing these vents spray some Kroil or PB Blaster (penetrating oil) on the bolts so they come out easier THEN dab a little antiseize on the new bolt threads.
Whenever I work on anything that exposed to the elements or extreme temps I always squirt some Kroil on the fasteners the night before and it really works well on helping to remove them...... Nothing is worse than breaking off a bolt or stud in a hard to reach place.
#43
I'm not sure about single (Exhaust Vents), but on doubles, when slowing and the throttle has been off for a while (like 4 seconds or longer) and the rpms have come down to the 2,000 rpm or less, and the FWOOOOOooooom, can be heard, if the throttle is gently touched, the cutest little crackle can be heard. It's just a single crack, but it sounds so SWEET. It's kind of like the engine is saying, "I'd make a helluva racecar engine too!"
The cool thing is, the car does this crackle from the factory. But it cannot be heard through the mufflers.
#45
No. Noone has mentioned these ever being brought up at an inspection. But I have had a guy do an inspection with these on (and posted in here in the forums somewhere about it) and they were not noticed. But that doesn't mean no inspector would notice ... some might. If an inspector did notice, and knew what the Exhaust Vents were doing, he would probably move on to something that mattered.
Another advantage is, if a person were very concerned these would be noticed (won't be noticed with the Stealth Exhaust Vents), take 10 minutes to remove them, do the inspection, and then 10 minutes to put them back on. After the original bolts are removed, the new bolts included should come out with no problems. Worst case, if an inspection were failed because of these, remove them, go through inspection again, put them back on after. Not a big deal.
I had a 1993 RX-7 that every year I had to jack it up, remove a large section of the exhaust, and put the original section back in that included the catalyst, muffler and connection for the smog pump. Then I had to put the OEM ECU back in the car. It would not pass emissions any other way. Now that, was a PITA. But I did it for many years. It was a Honda Civic with the cat, muffler and OEM ECM installed. It was a big nasty tire shredding monster with the straight pipe and aftermarket ECU. In comparison to that, removing and installing Exhaust Vents are like removing and installing a music CD into the audio system. So easy.
