Hazy look on black interior
Old 02-21-18, 05:07 AM
gte819s
gte819s's Avatar
Default Hazy look on black interior
My middle console has a hazy or waxy look that i am having problems removing. I stopped short of scrubbing it as i don't want to damage the soft finish but i tried a few different interior cleaners.
I dont typically put any surface treatment like armor all in this area, its not from anything from a passenger, and its not hit with any UV. The other surfaces that have the same texture do not have this haze. Its not sticky, it just looks dried out or chalky.
Anyone else have this going on? Any idea on how to deal with it and get it back to black?
Old 02-21-18, 05:26 AM
greg3852
greg3852's Avatar
If I had to guess you have an early model 460? If so check out these threads. Some years were covered by Lexus.
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/862122-i-have-2007-ls460-with-sticky-and-cracked-door-panels-and-dash.html
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/862122-i-have-2007-ls460-with-sticky-and-cracked-door-panels-and-dash-3.html
Old 02-21-18, 06:25 AM
gte819s
gte819s's Avatar
Thanks for the reply. I have a 2010 and Im not sure its the same issue. The plastic is not sticky and the affected area is not in direct sunlight.
Old 02-21-18, 07:08 AM
R Z
R Z's Avatar
Have you tried Lexol cleaner and conditioner?
Old 02-21-18, 08:49 AM
Dx3
Dx3's Avatar
It's the same issue.
Old 02-21-18, 09:24 AM
UDel
UDel's Avatar
Try some woolite and water and a mild brush and try some gentle scrubbing preferably on a area that is not very visible and see if there is any difference. Unfortunately I don't think it is going to work and those light hazy areas are not going to go back to black or its original color because the color has faded from the interior/dash/panel melting issue that affects some(too many) LS's. Once it can be confirmed that it is not something on your dash I would contact Lexus corporate and tell them your issue and complain, this should not be happening on these cars and owners should not have to pay thousands of dollars to rectify it.
Old 02-21-18, 09:50 AM
fb182
fb182's Avatar
Looks like the previous owner used an overly abrasive cleaner. Try applying this as it might save you some big bucks.
Old 02-21-18, 10:12 AM
JLAWS
JLAWS's Avatar
Get this stuff at a Toyota dealership. I have a couple of bottles for detailing jobs. I planned to get more but there seems to be a supply shortage! Now prices are starting to creep up everywhere !
"Vinyl and Leather Protectant is a silicone emulsion-based cleaner that restores and protects vinyl and finished leather surfaces from excessive wear, discoloring, cracking and peeling. This product should be used regularly to keep surfaces clean and prior to application of the Vinyl Rubber Protectant. Does not contain phosphates. Active ingredients include humectants and emollients. For use on vinyl, leather, plastic and rubber trim, bumpers and tires"
Old 02-22-18, 10:39 AM
Luscombe8A
Luscombe8A's Avatar
I would try this stuff and stay away for the silicon based products.
The reviews are awesome. I use this on the vinyl, plastic and leather in my Vintage Alfa.
It's called 303 Aerospace Protectorant
Amazon.com: 303 UV Protectant for vinyl, rubber, plastic, tires and ... Amazon.com: 303 UV Protectant for vinyl, rubber, plastic, tires and ...
https://www.amazon.com/303-Protectant-plastic-finished-leather/dp/B0185PU38A
clemgrad85
03-23-08 05:39 PM
RandyG
08-30-07 03:28 PM
BottomsUp
09-14-06 09:15 PM
OneOfOne
05-09-06 07:13 PM
R Tyler
03-28-05 12:31 PM
Quick Reply: Hazy look on black interior
