Scan is reading these codes. This is dued to power steering failure. Running through flooded areas before this occurs. Let me know what you guys think I should start ..
Hey
how are you doing ? I was wondering were you able to fix your C1532 i ended up changing the rack and pinion but didnt work did you change your steering module i just wanted to make sure
thanks
