Lower Control Arms
Old 02-26-18, 09:46 PM
Walking
Walking's Avatar
Default Lower Control Arms
I searched the forum and could find this problem, so if this is a repeat I apologize.
I am attempting to replace the lower control arms on my 2008 LS460 (110,000 miles).
Unfortunately, I cannot get the ball joints out. I have torched it, bent a pickle fork and hammered on it endlessly with a 5lb sledge. It hasn't budged an inch.
Is there some hidden pinch bolt or something I am missing?
Old 02-27-18, 03:56 AM
texas008
texas008's Avatar
I remembered that Scotty Kilmer somehow cut the ball joint of my LS460 with a dremel tool.
But I'm not sure if that is the only way/ correct way of doing it.
Old 02-27-18, 10:55 AM
UDel
UDel's Avatar
Can you use a pitman puller?
Old 02-27-18, 08:24 PM
sha4000
sha4000's Avatar
This might help you.
​​​​​​https://www.clublexus.com/forums/ls-...-07-ls460.html
Old 02-27-18, 09:24 PM
Walking
Walking's Avatar
Ya, I tried all of that as far as I can tell.
Also, that ball joint seperator is too small to fit around the front control arm.
Argggggggggnnnhhhhh
Old 02-27-18, 09:28 PM
johnnyg66
johnnyg66's Avatar
Not sure how a shop replaced mine. Maybe a air chisel. ??
Old 02-28-18, 07:00 AM
sha4000
sha4000's Avatar
I have to take a look at this ball joint when I rotate the tires again. This seems like a big headache.
Old 03-01-18, 09:44 AM
derpie
derpie's Avatar
I used a map gas torch and a 5 lb sledge .
Old 03-01-18, 11:32 AM
roadfrog
roadfrog's Avatar
I'm a staunch DIY'er, but this is why I left this job for a shop to do. I know some have had success doing it in their garage, but FAR more stories are similar to yours. For the 700 dollars my local shop charged to do ALL 8 arms, and two ball joints as well as a wheel alignment, I was happy to fork over the coinage.
icon901
10-12-21 02:23 PM
Speedc4s
12-13-16 08:39 AM
CManolo
12-05-14 03:35 PM
02Ku
10-01-09 02:20 PM
questnyc
Suspension and Brakes
05-17-08 09:49 PM
Quick Reply: Lower Control Arms
