Brake actuator noise
Anyone have any idea how long the brake actuator will last once it starts making noise?
I have diagnosed the noise I'm having and it's my actuator, it's not something I'm thrilled about but I intend to drive it like this until it fails...wondering how much time I've got.
Also I'm wondering if Lexus would "goodwill" an actuator on a 07 with 175,000 miles on it? Probably not. Bummer because if this had just completely failed before December of 2017 it would have been covered under that extended warranty.
Actuator noise wouldn’t have gotten you a replacement (unless you were one of the lucky few). The noise isn’t failure, it’s just noise and likely choppy breaking. In order for you to get the warranty enhancement, there has to be failure of the actuator (lights coming on). From what I’ve read and experienced, it may never fail. It will continue to give you the noise and “non-smooth” braking.
But i I will say that's the noise is unacceptable for a car like this, it's a bit embarrassing when you're driving the car to have a noise like that, I feel like I'm driving around in a Chevy Citation or something right now.
Some replacements start making the same noise according to my shop
Mine's been making noise for at least 18 months, as that's when I purchased it.
The non-linear braking feel can be rectified by EBC Yellowstuf pads. After your OEM rotors warp, I highly recommend some EBC rotors, too. The combo completely changes how the brakes feel on this car. From utter crap to pretty good for a land yacht.
Mine, equipped as above, are light years better than the OEM stuff on my wife's '17 RX 350.
Interesting post as my local independent shop installed the EBC pads and rotors on the front of my 08 LS.
you are correct about changing the “feel”. Less grabby. Especially at lower speeds.
service advisor says the oem pads and rotors were “soft” and the EBC are “harder” and the pads are “ceramic” and will last much longer.
talked me out of turning the oem rotors down to correct a low speed application pulsation. Done a lot of these it seems.
brakes still strong at faster rotor speeds just less at low revolution speed. Which is good. No grab requiring conscious lessening of pedal pressure as you came to a full stop.
