transmission drain & fill data
Have done 5 transmission drain & fills during past 16 months.
Keeping a record here, to compare notes with other DIY'ers.
Date Temp Drain Fill
5/07 65C 2600 2250
5/12 40C 1600 2000
------------ original post here: -------
The latest D&F was on 5/7, did it 1 hour after the commute, drained out 2600ml, fluid temperature ~65C.
Filled back 3 quarts of new fluid, start car, shifted between gears for a minute,
and then when draining out the excess trans fluid, I closed the overflow plug before reaching "thin stream" to compensate the higher than required fluid temperature (35~42C). Was able to back fill 2250ml at fluid temp ~ 65C.
Probably the transmission is lacking ~300ml of fluid, which means ~3% error, considering 10.5 quarts of total transmission fluid.
ATF fluids are mostly base oil, assuming a thermal expansion coef. of 0.0007, total volume of 10.5QT (9933ml), temperature increase of 40C, the volume expansion is 0.0007*40*9933=278ml, very close to what was observed.
5/07 65C 2600 2250
5/12 40C 1600 2000
I wish Lexus and other brands kept the damn transmission fluid check dipstick. My 2008 has 95K miles and runs very smooth. The Lexus and Toyota dealers wants over $300 to do a flush and fill. I'll problem let them do it for me since the drain and refill at the same amount might not be the correct amount going back in if I do it. Small price to pay vs damaging your transmission
thanks a lot for the advice.
wondering if the transmission level accuracy is really that critical,
considering a total of 10.5 quarts of fluids, a 300ml error means 3% of total fluids.
Steve runs a cleaner first through the trans with his backflush trans fluid change. Then switches the valves and fills the trans with 16 qts. Engine running.
He mentioned that the 92-95? Es300’s had a replaceable “filter” in the trans. No others. He does not drop the pan. Was a dealer service guy for many years before opening his own shop.
Guy at the dealer said its critical not to underfill it, and he's supposedly seen trannies ruined from it rather quickly.
LS460 transmission fill temperature range is
If you are filling at 65C, you have undefiled.
It doesn't really matter at what temperature you are draining. Filling needs to be in the range.
(LS430 transmission fill range is 45-55C)
35-42C
texas008 (05-11-18)
The service interval book from Lexus new states no maintenance needed and the trans part in the fiche is a “strainer” under
the details.
Why would they put in a “filter” then tell you not to service it?
He mentioned the one model Lexus that had a filter that required servicing. In the parts fiche for all LS’s call the trans part a strainer and no service needed on any of the models.
the details.
the details.
I remember when BMW and many others claimed "no maintenance required" on their transmissions (such as my 7 series and X5), until companies like ZF said, "uhhhhh no, you can't do that. Even our transmissions need servicing".
mckellyb (05-12-18)
Just be aware that this only applies in the US of A. Here in Canada and everywhere else in the world, the manual states regular fluid changes "every 72 months/96,000 kms", (55,000 miles). I have my Maintenance Schedule right on front of me. The fact that the US is different is only because of marketing. Lexus wants to be competitive with other manufacturers. I remember when BMW and many others claimed "no maintenance required" on their transmissions, until companies like ZF said, "uhhhhh no, you can't do that. Even our transmissions need servicing".
I have no problem with the BG trans flush cleaning agent or whatever they are using. This doesn't scare me at all. It seems Lexus is calling the paper filter a strainer I get that. I don't even feel its a big deal that nobody is changing the paper filter. In my car I want the paper filter changed though. By the way, the mesh strainer that is in some cars does deteriate and tear. I have seen this happen many times. Nobody ever pulls a pan and even sees the mesh is torn. Not the case in a LS460 because its paper.
BG Quick Clean for Automatic Transmissions is a safe and effective solvent/dispersant cleaner that will quickly remove accumulated deposits from the valve body, filter screen and other automatic transmission components. This product is designed for use in the BG Power Flush and Fluid Exchange System.
note filter screen...
