20 Inch Wheel Fitment
My friend with a 2008 LS600hL awd has found a deal on a set of 20x8.5 aftermarket wheels, bolt pattern seems correct at 5x120, and the offset is 33mm. Will these fit without issue? Car is completely stock, and originally came with factory 19's, but the previous owner ran a set of factory 18s for the winter and of course the 19's were nowhere to be found when the car was traded in at the used car dealer where my friend later purchased it.
Also I did check the wheels/tires sticky thread, but only found two set ups posted there with 20x8.5 front and rear (35 offset for one, 31 for the other), and neither appeared to be AWD models or the 600hL. I'm thinking 20x8.5 and 33mm should fit no problem but wanted to make sure.
ISSI1012
02-15-24 10:54 AM
