Need help with wiring
Hi guys . I am trying to run the fog lights independently ,
i have the wiring circuit and everything ready . But the problem i am facing is that how do i route the wiring to the inside of the car . The engine is so packed i cant really locate anywhere to route the wires to the inside of the car
any help would be appreciated
thanks guys
thanks guys
I haven't had the need to use on, but apparently there is a pass through or rubber grommet located on the firewall - I just can't remember if it was on the driver, passenger or both sides.
Yes there is one on the driver side near to the brake pedal . But i cant understand where it will come out on the engine side ..
that area is fully cover with abs and its parts ...
Hard to see down
Hard to see down
Easiest way is to stick a straightened-out coat hanger wire through the grommet and see where it comes out. I've also used a very long skinny screwdriver
LexusBiz
13
05-11-06 07:46 AM
abutler696
01-28-02 12:49 PM
