EPS codes , installed new EPS MODULE
okay, i tried to replace the EPS module, which is the ecu, from what i know we had to get it recalibrate at the dealer. so i brought it up to the dealer to get it flashed, in order to flash it, the DTC codes had to be cleared before performing the CALIBRATION. they couldnt clear the code, or it would come back..
1.replaces lower controle arm , (alignment pulls to the right )
2.(drove through about 2ft of highwater 3 months ago ) powersteering went out, checked all fuses, they were ok
3.tried the start button trick pulling the wheels left to right, ( worked for 2 weeks max )
4.on the road, it completly gets no power assist, like the eps just went out.. tricks doesnt work any more...
5. continue to drive without the EPS and alignment
6. eps top pigtail cracked, but still connected (not sure if its a issue)
7. purchase used eps with matching part #
8. install , alignment done.... now cant flash dued to DTC wont clear to perform calibration
i have been driving 3 months like this,
