Spark Plug Tips
Spark Plug Tips
I feel this deserve its own thread. I want to save people hours or days. I spent last 2 days changing spark plugs. I guess it's an initiation for me as a new owner of a 131K miles, 2007 LS 460. my intro
I changed the engine oil, spark plug and cleaned the MAF sensor. Thanks for this link.
DIY Link
I spent hours using crow bars, tire iron moving engine a few millimeter, if at all. I even saw the youtube video below too for tips.
Here's what I found out. There are 2 seals. I had to make sure the 2nd seal was removed. Once I removed the 2nd seal, the spark plugs and coil went in and out with out any issue. No crow bar needed.
A few of spark plugs were heavily drenched in engine oil. I am changing the valve cover gasket and spark plug tube seals.
ebay link tube seal good deal
That's a good deal I found. For comparison, another ebay seller wants $7.28ea, not for whole 8 seals.
very helpful thread.
CL-Oil Leak
found these part numbers:
Part #'s
2 - Gasket Fuel Pump SP 23224-38010
2 - Insulator, Fuel Pump 23915-46011
4- Orings 90301-A0029
4 - Fuel Pressure Gaskets 23279-74010
More things to be done:
I am waiting for someone to tell me where PCV filter is in another thread. I looked for it and thought it was the one on the valve cover. No. I removed the tube and it looked nothing like it.
I am definitely changing the transmission fluids. The previous owner had been serving his car at the dealer but I did NOT see any transmission fluid or spark plug changes up to 133K miles. Unbelievable. Lazy dealer.
I am dropping the pan, changing the filter and refilling with fresh fluids. link
https://www.clublexus.com/forums/ls-...nd-filter.html
Hopefully, I can do that without going through techsream. But I did order techstream off of aliexpress.com, btw.
DIY Link
CL-Oil Leak
Part #'s
Should have searched and read a little more, I know this is documented here somewhere because I knew this going into a spark plug job within the last 1-2 months. Did them all and had everything back together in 1.5 hours.
Thank you for the YouTube video. However, see this thread: https://www.clublexus.com/forums/ls-...eplacment.html where Chris (roadfrog) stated: "NEW INFO: Recently it was noted that another option to using a pry bar, is to simply remove the rubber gasket surrounding the coil packs. This allows just enough room to get the coil pack out easier. To remove the gasket, there are slots in them that allow to insert a screwdriver and pry it off."
one of the bolts holding down the module.
Carefully loosen the 2 white fasteners underneath the connectors. Once loosened, the connectors can be gently pulled out underneath.
