Ls460 oil capacity
Old 06-14-18, 05:24 PM
Richardgil
Richardgil's Avatar
Default Ls460 oil capacity
had ls430 oil capacity about five quarts. My ls460 requires 9.1 quarts. Why the big change?
crown300 (04-13-24)
Old 06-14-18, 05:37 PM
Received 2,730 Likes on 1,956 Posts
Because of the direct injection and the timing chain in the 460 engine. They went to a much larger sump to guard against contamination of the oil.
The following 3 users liked this post by SW17LS:
Boomin (12-03-20), crown300 (04-13-24), mambo619 (05-17-19)
Old 06-14-18, 05:56 PM
Richardgil
Richardgil's Avatar
Thanks. Appreciate it. Been trying to get an answer' , but not much luck.
Old 06-14-18, 06:41 PM
No problem!
Old 06-15-18, 01:12 PM
bigsherv
bigsherv's Avatar
man I think it is like 9.1 quarts. I bought two 5 quart jugs and had some left but not much
Richardgil (06-16-18)
Old 06-16-18, 11:06 AM
Richardgil
Richardgil's Avatar
thanks for the reply. It is 9.1 quarts.
Old 05-16-19, 09:45 PM
vamfoom
vamfoom's Avatar
I have the 2015 Lexus LS460. The owner's manual says it needs 11.6 quarts. I was at Oreilly Auto Part store and their system says it needs 9.2 quarts. When I changed oil earlier today, I put in only 10 quarts then checked the dipstick which shows it's already past full. This means that the manual is wrong and that the dipstick agrees with Oreilly. How can it be that the manual is inaccurate? I confirmed it's the correct manual for the car.
This means I have almost a full quart extra. Should I bleed the extra oil out?
Old 05-16-19, 10:07 PM
jkittlesen
jkittlesen's Avatar
Yes you should!
Old 05-17-19, 04:37 AM
fwhomeboy
fwhomeboy's Avatar
CAPACITIES:
Engine, with filter..........9.1 quarts [1]
Cooling System, Initial Fill..........11.6 quarts
You might be confused with the coolant.
Old 11-30-19, 07:26 PM
mike3582
mike3582's Avatar
I believe it says 9.6 liters not quarts
Old 11-30-19, 07:58 PM
No, it’s quarts.
Old 12-01-19, 03:08 PM
ALK
ALK's Avatar
This is my reference.
Old 12-01-19, 04:55 PM
Nospinzone
Nospinzone's Avatar
I didn't see this thread when it was active earlier this year, but I will say you are far better off being a quart under full than a quart over. If you are over the full mark, I would definitely drain off some oil.
Old 01-28-20, 05:10 PM
gs300lexus
gs300lexus's Avatar
better go make some money and call that lawyer after something happens to your motor because of over filled oil, that’s if your book says 10.2 for fill up, and I believe it said 10.2 for dry fill lol but hey if your manual has error make that money
Old 01-28-20, 06:51 PM
BMW7_LS430
BMW7_LS430's Avatar
This is from 2016 manual. It is different for RWD vs AWD.
I used put 9.5 in my 2011 and as per the specs I overfilled a little. But then I used to drain oil overnight maybe thats why I never saw it on the dipstick.
Quick Reply: Ls460 oil capacity
