LED LEDs in car CANBUS or NON-CANBUS?
Hi all,
Looking for a LED upgrade in the interior and corner lights. For the interior lights, anyone know if the proper bulbs should be CANBUS or NON-CANBUS?
For the turn signals, i searched that it will hyperflash if used with an LED bulb. Does anyone know where we can get a flasher relay that will support LEDs or a proper hyperflash plug and play kit?.
Since you do not have leds to in either end of your vehicle for your model, you just need a resistor to balance out the load, these are cheap, you can run NON-CANBUS just fine, no 'warning' lights will display on the dash if that's also what you're worried about.
Get the resistor and you'll do just fine for the turn signal lights.
For the interior bulbs it's the same thing, minus the resistor obviously.
rclab1
01-12-08 11:16 AM
