How to update US spec 2007 LS460L with Ukrainian/European maps?
So i have called a few dealers their software and equipment only work with European spec cars is there a way to get European maps on my US spec vehicle?
THANKS !
THANKS !
I think you are out of luck. You would have to have a tech from the US come over there with the software and computer to do it. I'm not sure even then it can be done because the US version probably doesn't even have European maps.
Your best bet is to use your phone or buy a GPS system.
http://www.beatsonicusa.com/
i think thats the only solution that may be able to resolve your issue, essentially mirrors your smartphone on the nav screen then you can have it with waze or google maps, might want to verify with them if they support the 07s though.
jdanielca (07-06-18)
The Beatsonic smartphone mirroring kit works only with 2013+ LS460s.
So any other solutions for this? its been 10 years and not one company has come up with a solution? Would appreciate the help.
Hi Daniel,
You can try installing an aftermarket head unit for the radio that will come with a display that supports Apple Carplay (and Apple Maps). Check post #24 in the following thread.
https://www.clublexus.com/forums/ls-...ad-unit-2.html
jdanielca (07-11-18)
