Tire Pressure Sensors
Hello,
I have 22" aftermarket rims on my 07 ls460. These tires do not have TPMS in them. I went on amazon.com and searched for about 2 weeks looking for the right sensors. I ended up getting Denso Item # 550-0103. So I take the sensors to my custom wheel guy and he charges me $150 to install them. When I pick up my car my dash says checking but it never finds. I dropped my car off again today while I was working and when I picked it back up it said the same thing. The guy said that they "wake up" but aren't recognized so he has to type in each sensors info. After he does that he said it shows up but then disappears later. I'm not sure if I believe him or if he's just trying to get me to buy sensors from him. I did take my car to tires plus and they tried to sync up and they told me that there machine cant find them.
Has anyone had any issues with buying sensors and them being defective?
What sensors work??
Amazon gave me a $5 coupon to help offset the $150 I paid to have them installed LOL. and since they are in my tires now..... I have to pay again to have them removed before I can even return them to Amazon for a refund. I need to find the correct ones so I can install them when he removes the Densos.
I called auto parts warehouse and they are telling me that they are a direct fit.
What sensors work??
Sensor has life span because they have battery in them. You need Tech Stream to DIY on registering your new sensor ids. into ECU. Or needs TPMS tool. I have Autel one which can trigger, scan sensors, read id.
frequency, temperature and battery status.
Then this tool can register those ids. into ECU by connecting the tool to OBD port. It takes less than 30 minutes for the whole job. Two frequnecies are used for sensors. Either you use univeral type dual frequency sensor or frequency specific for your car.
Hello,
What sensors work??
What sensors work??
You may have a problem with tires that are not compatible with the TPMS. This potential was realized during the Rule Convention.
Here is a clip from the final rule: [36]�The RMA submitted information on the prevalence of tires with characteristics identified as potentially being incompatible with proper TPMS functioning, at least in some cases. These problems are primarily related to the tires' construction (e.g. , high carbon content in low aspect-ratio tires, thicker sidewall, or steel body ply sidewall). According to the RMA, in 2002, light vehicle tires having either steel body ply cords (steel casing tires) or run-flat capability accounted for less than 0.5 percent of tires distributed in the United States. (See letter from Steven Butcher, Vice President, Rubber Manufacturers Association, to NHTSA (October 31, 2003) (Docket No. NHTSA-2000-8572-282))
Sams could not do it either. Said my tires are rated for 95 and minimum for my car is 97. So i asked would if I took the rims and tires off my car and brought in. He said that would be fine except that since my rear tires are like 10 1/2 inches stretching the tires over 25 series tires is the next issue. The mechanic there thinks the guy that put my last sensors in broke them putting the tires back on. Their machine is reading a sensor but its failing everytime.
I know that this has been frustrating for you. Thank you for sharing your experience with us.
solved... i went to a different tire shop today and the guy synced my tpms in 5 minutes. the only thing he did differently than the other guys was hold the machine on my tire to read the sensor through the rubber, instead of through the rim. THEY WORK!~
jmcraney (07-25-18)
Fwiw, if you get the id's he found for each one and write those down then get him to scan your OEM tires if you still have them and write those down too. Then get Carista app and OBD connector and you can DIY whenever you need to. Also change all your personal settings and diagnostic the car at home. The stealership charged me $100 bucks to turn off daytime running lights when I first got my LS. smh
