Highly recommended for all ls owners
Looks very nice! How hard (or easy) is it to install? Do we have to remove our taillights or is that velcro bit enough access? Would be very interested if it was a simple install/plug and play. Thanks!
Took all of 2 minutes to install. No need to remove the whole taillight. Just remove the velcro, replace the bulb, and you’re good to go. Very simple installation.
CarGuy89 (08-16-18)
Thanks! I took a look at lunch today and the bulb does come out easily. It sounds like it's just plug and play. I will add it to the list of things to do eventually. Thanks
Hi.
No, I live on Fort Worth side. Dallas is where I am from, but got out as fast as I could.
This is side is friendlier, kind of like Dallas used to be.
anyway, looking forward to new bulbs. Also, while your job situation is scary, I am sure you are good at what you do so you probably won’t have too much trouble. Thumbs up for success.
Hi.
And for being only 35 miles distant, yet in the same country, these cities could not be more different in attitude.
Hi all:
I received my bulbs today and and very easy to change.
Wow, what a difference in brightness. I am very happy the OP put this thread out.
I really feel now now others will be able to see the flasher easier and hopefully make the necessary speed changes.
Thanks again.
Best
Thanks again.
Best
Hope all is going better on your shock projrct and work.
Best,
The list shows the rear turn signal bulbs should be clear, but the bulbs in the link are amber. Does it really matter?
Hi all:
Thanks again.
Best
Thanks again.
Best
Best
dfrosch (08-19-18)
