VSC off, VSC trac off, ABS Lights on, all 3 lights on.
Old 08-14-18, 02:21 PM
Redeemed07
Redeemed07's Avatar
Default VSC off, VSC trac off, ABS Lights on, all 3 lights on.
Yes, I got the dreaded 3 lights warning lights of hell, the funny thing is that they only come on when I push brake pedal AFTER engine is running and no error messages appear until I push pedal, the brake actuator was replaced by dealer a year ago, sometimes, when I turn off and on car the error messages will dissapear until I shutoff engine and restart it again, I have checked car battery voltage, it was a bit low, but it has been recharged and is holding charge ok now, I have checked brake light switch and when disconnected it won't even allow car to start again, could it be that there is air in the brake system? Also, I have opened and closed brake fluid reservoir and restart car again and warning lights dissapear for a while, I don't believe it is the gas cap either, because I do not get the check engine light either, so, has anybody encountered this problem before and know the posible cure?
Old 08-14-18, 02:44 PM
TriC
TriC's Avatar
First thing is to see what, if any, codes have been thrown.
Old 08-14-18, 04:01 PM
john341
john341's Avatar
Maybe you need to do the zero point calibration. Just a guess.
Old 08-15-18, 07:08 AM
Redeemed07
Redeemed07's Avatar
The thing with two small paper clips sticking in into diagnostic port? Can
Old 08-15-18, 07:51 AM
Redeemed07
Redeemed07's Avatar
Sorry for not answering earlier, needed to hook up diagnostic OBDII, there are NO codes and none stored up, this morning I started car up and as soon as I stepped on brake pedal the lights lit up again, then I shutoff engine and restarted again and lights are not present anymore though I depress the brake pedal, the lights do not light up, battery trouble? I connected volt meter reader in cigarette lighter and when engine running I get 14 volts, when I turn off engine and leave it in the on position, I get 12.70 volts going down to 12.40 volts, is that acceptable? Why I am not getting any trouble codes with obdII tool and my battery warning light is not lit up?? Help !!
Old 08-15-18, 09:40 AM
Jasoneo5
Jasoneo5's Avatar
Only time this ever happened to me was when my battery was going bad
Old 08-15-18, 11:26 AM
Redeemed07
Redeemed07's Avatar
yeah, that is what I think too, might recharge battery, though battery is still under free replacement warranty I don't trust the dealer....
ThatGuyJ
08-27-19 05:06 PM
lexseed
GX - 1st Gen (2003-2009)
10-20-15 03:45 PM
dscokin
10-14-08 09:40 PM
jonahb
Maintenance
03-25-08 09:56 AM
Quick Reply: VSC off, VSC trac off, ABS Lights on, all 3 lights on.
