2017 LS 460 Rear View Camera Not Aligned
Has anyone had this problem where the wheels are straight and the yellow lines are not straight?
See these pics below. https://imgur.com/a/RayQUIu
Straight wheels
Yellow lines not straight with straight wheel.
Wheel turned
Straight yellow lines with wheel turned
Straight wheels
Wheel turned
Never seen that issue before. Likely some sort of a calibration issue, dealer should be able to take care of it no problem.
Straight wheels
Wheel turned
Straight wheels
Wheel turned
Same issue did you ever get resolved? Was it necessary for dealer to do or any “reset” you could do.
XF40FSPORT (09-25-22)
I found this on youtube after having same issue and it worked perfectly.
Good Luck
https://m.youtube.com/watch?v=dPrXq3xKz5s
Good Luck
yep, that was it. The biggest thing is just making sure you hold down on on the remote touch and it has a little bit of a delay in the commands but it works. Thanks so much.
