Great Milage
I have driven from California to Utah, Michigan, Texas, and Missouri and still kept cruise control off. I must say I am amazed how smooth the roads are in other States. I remember crossing from Arizona back into California and the smooth road literally became broken concrete the moment I crossed the border.
How many miles did you drive on your trip odometer and how many gallons of gas did you put in when you filled up? The true measure of mileage. I just got 29 MPG, 549.9 on trip odometer when the fuel light, put a little over 19 gallons of gas in when I filled up. Probably could have driven another 20-30 miles with the light on.
After replacing the fuel pump in my old 1995 LS400 5 years ago, the auto mechanic mentioned he would not drive too much under 1/4 tank of fuel as gasoline can slosh around and cause air pockets to be stress pumped through along with less liquid gasoline cooling of the fuel pump, which can lead to a fuel pump failure. Refilling at around 1/4 tank also causes less worrying about being able to find a gas station before running out of gas.
In regards to your picture, the crushing range and mileage are reversed on my 2013. The crushing range is below the mileage on my car. Is the customizable?
Cruising range, yes I did proof read and my eyes saw it correctly but obviously it was not. Sorry.
jskennedy
RX - 3rd Gen (2010-2015)
34
06-24-11 02:39 PM
