Coolant leak at 96K miles
It was leaking pretty good and coolant in the reservoir tank went from full to below Low line in four days, yet engine temps never rose, no smoking nor smells, and no drips or puddles underneath the car. There was no way to see the leak from above the engine until the late stages and only if you knew exactly where to look. I can see it now through a crevice from the top but could not see it at all a week ago, even with an endoscope camera. It was still Summer temperatures outside so I didn't use the heater yet but apparently that is a telltale sign of a leak if you don't get enough heat. Sometimes the AC blew too cold but I just proudly thought the system was working too well. I am just glad it wasn't a head gasket leak.
The following 3 users liked this post by FatherTo1:
That's a good tech you've got, he quickly diagnosed that thing. Price doesn't sound ridiculous either.
FatherTo1 (10-19-18)
Yup, leak near the valley plate of the vee. The underbody covering must have been catching the drips and preventing puddles beneath the car. Mechanic says this is common in the IS cars and Lexus V8s at 100K miles and even ES/RX 330 at 150K miles. The factory seal wears down over time and needs to be redone. It is a 5-hour labor job. Initial estimate is $570...which I consider not too bad, although I am disappointed from the Lexus flagship. This issue is not present in the LS 430 because the material or design in the valley of the vee is different.
Just being proactive and checking regularly should be sufficient, although I know it's kind of a hassle to remove all the paneling just to take a quick peek.
In short, here are potential symptoms:
-Coolant keeps disappearing, yet no drips or puddles under the car
-AC appears to work too well
-Lack of heat at idle or not enough cabin heat during cold weather
-Coolant stain near transmission (you can see this underneath without raising the car, but probabaly even easier to see for those with the air suspension and Height High option)
-Lastly, I haven't confirmed if this is actually related to coolant leak yet, but I notice a lot of crackling sounds when I turn off the car. I know it is common with the expansion of aluminum engines and contraction as it cools but I am curious if I'll hear less crackling sounds after my coolant leak is fixed. The LS 430 doesn't make any crackling sounds after it shuts down (well, maybe just one or two pings).
Looks like I have a similar issue. Car has very low miles (about 17k now) but original owner did not maintain the cooling system and the second owner swapped the fluid with non-OEM. Bottom line, I have coolant running down over the rear of the passenger side valve cover and need to keep refilling the reservoir every few days. I do not know if the issue is just the o-ring or also the valley plate seal. Anyone have a good recommendation how to test it? I suppose I could buy a simple pressure test kit and try to isolate the leak.
FatherTo1 (05-21-19)
FatherTo1:
Appreciate your reply to my post. I've just been researching this topic and specifically reviewed the photos you had posted as well as the shop manual. It appears that there are two coolant bypass lines (steel lines) which then connect to rubber hoses right above the rear passenger valve cover. I can see that the leak appears to be dripping down from above the valve cover itself, so I'm now suspecting this may be a somewhat different issue than either the o-ring or the valley plate. I will dig into this in the next day or so and see what I am able to determine and post back here. It would be better if this was in fact one of those coolant bypass lines I mentioned as I suspect it may be an easier repair. Also, I know for a fact that the prior owner had his local shop (not Lexus) do the coolant exchange, it would not surprise me if that shop messed around with those fittings to help bleed the system afterwards. Of course, I'm quite sure they did not have the shop manual nor did they realize that there was a bleed valve at the upper radiator hose connection to the radiator.
Reminds me of the dreaded "coolant pipe leak" found in the BMW 4.4 V8's. I had it in my 7 series BMW. It was a MAJOR job that was extreme drama to replace.....to the tune of 3-5k dollars.
