headlight
headlight
my 2007 ls460 headlight turn on every time i start my car, after about 20 minutes or so it shuts off. if i turn the car off and then on again it comes on and then it turns off after 20 minutes or so. is this bad bulb or is it heating up and turning off?
This has been discussed in our forum a while back.
Check here: https://www.clublexus.com/forums/ls-...e-back-on.html
A bad bulb because I had the same problem and a new bulb solved it.
