Front jack points? LS460 FSM photo isn’t that clear
My Uncle's HF slid perfectly beneath the LS with maybe 1/4" to 1/2" inch to spare from the highest point of the jack. The entire jack ended up beneath the car and the handle was probably 6" inside of the bumper's lip edge. At first I could only pump the handle a few inches until the front end was higher up, but it all worked out fine without having to force the issue..
I use my 1-1/2 ton jack to lift slightly on one side behind the front tire, then use my 3 ton HF jack to lift at the center lift point. It is easier to the see the semi-circular area that way.
agunjal
11-15-14 02:42 PM
