Just had this issue and reset the maintenance light yesterday. I also plan to go 7500 miles on full synthetic, but I think the light comes on at 5000 miles even if you set the reminder to 7500. Here's the reset procedure from the owner's manual.
I think it has 2 reminders one you set in the maint screen will pop up on the screen. The other is dash set reminder. I do not think you change the dash cluster reminder only the touch screen reminder.
The reset procedure above will make the dash light disappear
SO, if I do the light reset now then the change oil will disappear when I start the car, AND I still will get some kind of alert when I hit the 2600 more
miles interval I programmed into the Maintenance software?
I think so, but not sure. I have about 2200 miles to go on the 7500 interval, and will find out in a couple of months.
The dash light and the reminder in the infotainment are not connected. The dash light will always go off at a predetermined mileage, the reminder from the infotainment system will go off whenever you set it to.
Yup, I'm pretty sure that's the case. I think the 5000 mile reminder is part of the Lexus dealership owner retirement program.
How will this reminder go off? Will a message appear on the Nav screen?
