Help. 08 460 LS L. VSC
help experts
pretty much ever since I’ve had my 460, I’ve had this light come on. I’ve many posts
and also googled it as well. Changed to an OEM gas cap Checked hoses
this is what shows up
fuel mixture system lean bank 1
how many have ran into this?
thanks
david
thanks
david
From what Ive gathered since Ive owned my car, its a light that pops up whenever the slightest thing is triggered. As stated above, his was fixed with the O2 sensor. Mines will trigger is there's a stutter while starting. Like if the battery is low. I will pull out the scanner and clear the code and it'll be fine until next time it does it. Usually if my car sits for more than 2 weeks with no starts.
