Help sound from front driver side
First I have a 2009 LS awd with air suspension I have looked at all the forums on this issue however my problem still persist I have replaced all 6 control arms on the front end sway bar bushings sway bar links and I just recently replaced air struts parts 48010-50260 and 48020-50260 however they were used with a 1 year warranty I even had the brakes checked today and they are completely good I have 2 videos below any ideas
video 1:
video 2:
video 1:
Let me start by saying I am no expert but I also have the air suspension if I read your post correctly. The roads here and horrible, there’s all sort of creaking going on. But it has been considerably reduced. After I sent 10 Euros for a guy to inspect my vehicle telling me I need new bushings in my lower control arms. At the same time I asked him to silicone lube all rubber suspension components and to tighten up all chassis bolts and suspension components.
Maybe try that first, sometimes the simplest things. Who is doing your work? Maybe bring it to a different place if someone is doing it for you.
Jeffrimerm
Suspension and Brakes
05-18-15 10:43 AM
