Anyone ever had to replace their shock mounts??
I don’t hear too much talk about the shock tops. Just checking to see if anyone was able to resolve a front and knocking by replacing the shock mounts.
The reason I’m asking is because I hear the knocking sound going over small bumps and the sound seems so close to me like it’s right behind the dashboard. The only thing I haven’t changed are the lower control arms because I would have to take the knuckle to a shop and have them press the ball out. Are you saying that it’s more likely the lowers causing this? And would the sound be that close?
i have the same problem the dealer first said control arms replaced still making the noise then air struts same thing even replaced sway bar links still making the noise control arm bushings everything I’m about to trade it in the suspension on this car is just poorly designed in my opinion
Please let us know how that is after. I replaced my bushings and it's still there, gonna go for ball joints next. : ( Man.....
Sway bar bushing and links were done to no avail! Definitely thought it was the swaybar bushings because they were dry and had a significantly smaller profile. When I was done the bar was nice and snug. But no change. it’s weird because every now and then I would hit something with the right tire and I swear I could hear it on the resonate to the left side.
I remember ber reading about the steering rack being loose how does one find and tighten that?
