Sticky/cracked interior panel customer support program notification - ZLZ
#181
Different material
I just picked up a 2007 Ls 460L American specifications lucky for me the car is in really decent shape. The dash, arm rest and center is showing little wear but with the desert heat in my location I am sure sure it will eventually start to crack. For whatever reason the previous owner never had this recall taken care of and read the car is past the date to have Lexus do it. I am considering having all the effect interior pieces wrapped in Alcantara or Leather just curious if anyone has done I tried looking for pictures on the Internet but could not find even one. Does anyone know how much material I would need to cover all the parts?
Parrokeete (11-02-21)
#182
Canada Sticky dash issues and chaulky white interior help needed
Hi - i have a 2007 Lexus LS460L . I have experienced the shiny sticky dashboard issue this year the most due to the heat, I rarely drive my LS (approx 3000km/year on avg). and feel that has delayed the sticky issue to occur. Lexus Canada said the warranty extension/interior replacement only applies to USA and not Canada which makes no sense as we get hot weather. Long story short they said it is wear and tear of the car and this can happen and my responsibility. The car literally looks like its out of a showroom as i keep it in mint condition.
Lexus Canada are not going to do anything to help me. My question is when the interior cools down it turns Chaulky white - see attached pics. I tried Aerospace 303 but makes no difference after a day it goes back to what you see.
Any help guidance would be appreciated as i plan on keeping the car but at the moment i am so disappointed every time i climb in.
For Lexus Canada to say this is normal wear and tear and is the joke of the century.
#185
The ZLZ program has expired for any covered vehicle with a date of first use more than 10 years ago and is still available for covered vehicles with a date of first use 10 years or less ago. So as of today, the ZLZ program is available for vehicles with a first use on or after 9/28/2011.
#186
Yes, I received mine. I missed the cutoff however, it is covered for 10 years from the date the car was put in service. I made that one by a few months. All of my items are in but one, the order was made in June so shouldn’t be long now. I’m in Nashville TN. Your local dealer can easily see when the car was placed in service. Good luck!
#187
I've had the same problem for my entire dash for the past 4 years on my 2007 460L given car spent most winters in Florida for 1st 8 years. I rec'd similar response from Lexus Canada 3 years ago but with emphasis on legaleese that Lexus Canada is a different entity than Lexus USA, really eh? Then they had the nerve to write that I didn't understand the difference about different entity....no comments required so my final response to them stated 'same car from same factory for both USA or CAN market, why does 'Lexus' treat Canadian owners differently?........
My experience with local Lexus dealers is similar in that; Lexus dealer 'A' who performed fuel rail recall, I had to go back 4 times to fix loose items! 2. Other dealer wanted $2400.00 plus painting fee to change my two loose mirrors which had a tech bulletin in US to replace 2 nuts, that cost me $250 to fix in the US and this dealer had the nerve to tell me this was a CDN car spec and the tech bulletin didn't apply! *lol*
In August this year, I tried Sticky Dash Fix out of Australia, worked quite well but colour is off slightly and after I advised them, they went out and bought a steering column cover to colour match more precisely. They advised will resend coating once match complete so I can recoat and awaiting. I will use a mini roller next time though to minimize small streaks. Hope this helps.
#188
I have ordered the Sticky Dash Fix kit also but am scared to do it but i dont see any other option. I still cannot accept that Lexus is not willing to stand by something they know is a known issue. I do not really care that they are specify which VINs are affected as they would reduce the number they would need to take care of. I think in the US, Lexus is more worried about lawsuits compared to in Canada.
Any tips or tricks or before and after pics when applying the Sticky dash fix? Did you do the glove box also? Are you in the Toronto area?
#189
YES! I received the same letter yesterday. I've been wondering what's up with my dash. I clean it with what the dealership sells, and a few days later, it looks, dusty and feels sticky in some spots. I chalked it up to the previous owner not taking care of it properly. Now I know that's not the case. Is Lexus obligated to inspect and repair at no cost the owner? I own a 2009 Lexus LS460. Sure do miss my 2000 Platinum Series LS 400 albeit 272,000 miles.
#190
Just curious so I'll ask here. Have any of you that have an LS that didn't get the ZLZ program fixed in time priced a non-ZLZ replacement? I'm debating buying a used LS for my mom but almost all the ones I see in my price range have the sticky problem and are no longer eligible. I'd like to know how much it would cost to replace all four door panels, the glovebox surround, the dashboard and the lower parts of the dashboard (i.e. like getting the ZLZ fix) so I can bargain with a seller.
Any help would be appreciated as I asked my dealer and they indicated they could not answer without the car in front of them.
Be safe,
Jeffrey
Be safe,
Jeffrey
#191
Be safe,
Jeffrey
Be safe,
Jeffrey
I am waiting to do the stickydash fix over the panels to see if that would work.
LuxeLexus (10-24-21)
#192
Be safe,
Jeffrey
Be safe,
Jeffrey
Protholl (10-09-21)
#193
Wow... yeah that is pretty steep its twice the budget I'm using for the car. Thank you for the response.
#194
Be safe,
Jeffrey
Be safe,
Jeffrey
Yes,
My cut off date was last summer. Never had an issue - that is until this summer. The car was parked on a fresh blacktop parking lot and it was a hot day here in Raleigh. The dash was fine but the armrests felt that they had a sticky gooey substance on them. I took my car to a local auto upholstery shop here in Raleigh and they are wrapping the armrests in Leather. The car will be ready today the cost is $1,000.00. I will post pictures once I get it back.
#195
Quick update - i am in the process of using the StickyDash.com solution and have put on 3 coats so far and am pleased how it is turning out. I know the weather is colder and not has hot but will see how it reacts in the Summer next year - but this at least looks much better than what it did before.
Before
After
Before
After
