Wheel guru's please chime in
Old 01-10-19, 12:03 AM
whytry
whytry's Avatar
Default Wheel guru's please chime in
i have been looking at wheels for awhile now, and read a lot from the above post wheel/tire info thread and want to make sure I'm understanding this all correctly. The more offset the more "tucked in fender" look correct? So a 21x9 with an ET24 offset front with 245/34/21 and 21x10 with an offset of ET40 with 285/30/21should fit with no fender mods correct? I have the 460l with the data controller also. For the rear I also know that there is a 21x10 with offset of Et24 but if I'm thinking about this correctly the Et24 offset would be more aggressive and with data controller on 3 in rear it would rub the fender, correct? This is part one of my question and I think it coyld answer my own question if I know the above first.
thank you,
Whytry
Old 01-10-19, 04:00 PM
PwrdbyM
PwrdbyM's Avatar
Use this offset calculator to compare: https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 01-11-19, 11:15 PM
whytry
whytry's Avatar
Ok thanks, what is the factory's offset for these cars?
Old 01-12-19, 01:06 PM
VanCityLS4
VanCityLS4's Avatar
Based on my more aggressive set up those wheels will fit. But the question is do the fronts have a high disk face to clear the factory BBK. You need (R disk) fronts. I’ve tossed out the data controller (trash) for coils. Couldn’t be happier.
factory 19x8 +35
Bigwun07
05-01-09 09:03 PM
Gs430Boi
03-11-08 08:52 PM
bee0818
07-28-07 03:48 PM
tonydt1g3r
Wheels, Tires & Brakes Forum
01-01-06 10:32 AM
financial guy
20
09-18-02 11:29 PM
Quick Reply: Wheel guru's please chime in
