Extended studs/adapters for ls460
whats up CL,
im looking for extended studs or 15mm adapters for an LS460. Can anyone guide me to the right place or person? Thank you
thank you. However I’m only to use a 8mm spacer that’s why I want to get extended studs, but I can’t find any so I may have to result in 15mm adapters if I can find some
I purchased a custom set from these guys: http://www.motorsport-tech.com/
Not exactly cheap, however there have been cases of substandard spacers and studs breaking causing the entire wheel to disconnect. Your call.......
Ling2IS
06-26-18 05:38 PM
myke441990
SC- 1st Gen (1992-2000)
13
10-05-10 10:00 PM
juguryan
05-12-07 08:27 AM
