2007 lexus ls460l air suspension is at very top! Can I reset it
So a friend of mine who's a machanic has a 7000 scanner when he hooked it up it showed the driver side height sensor showed 0 and all the others were 7.4 etc so this caused the air ride pump to run constant to attempt to make the driver side sensor reach equal levels. So when he pulled the sonsir and tried it on the right side passamger it registered a reading. Then cleaned the terminals where the faulty side was..that didn't change things. So then followed the wires back to the computer located behind the globe box on the right side. Then after 2 hours he then went back to the sensor location on the driver side and and with a very bright led light and noticed in the actual female receptivle a coroded wire almost impossible to see..he swapped out the wire reinserted the male sensor plug and it then be an to show a readimg! Now keep in mind before I got there I was just considered getting the strutmasters air ride alternative So as of now all is great and she rides great again
I hope this helps someone and saves a bunch of money at the same time
oldkystude (07-11-21)
