HELP!! How to unlock all doors when driver door is opened?
I’m tired of opening my door via the inside handle (whilst the car is running), to go around to unload the back seat and the doors are all locked! How do I unlock all doors when I open the srivwr’s door? I’ve tried to settings and nothing improves! Help!!!
Depending on what year your car is it's either a dealer configurable option or something you can do yourself in the car setup menu. If I remember right you can lock and unlock the doors based on whether the car is in Park or not, or based on speed of the car (maybe this is only to lock the door, not sure)
The default setting is for the car to unlock all doors when you put it in Park.
The Settings menu / Vehicle Customization / Door Lock may have been
changed.
changed.
Everything said above is correct, this is a configurable setting however not all years have the feature available for owner manipulation. If you don't see the settings in your screen you'll need to utilize a device (Techstream/Carista metioned above).
Mine is an 08 and I remember changing the door unlock function.
The instructions are in the manual Page 38-39 "Switching the door unlock function". Manual says hold a door handle to unlock all doors.
Hopefully this helps.
jeeper2269
12-11-16 11:11 AM
Kristin
RX - 1st Gen (1999-2003)
12-23-02 03:19 PM
