help, adjus the oem air suspension height
help, adjust the oem air suspension height
hi guys new to here, my car is 07 ls460 japan import (im in new Zealand ). im trying to adjust the sensor link to lower the car, i have done the front ones was pretty easy no problem. but when im doing the rears, the car doesn't drop. anyone know what might be the problem? thanks
Trblpinoy1 (08-03-19)
You may need aftermarket lowering links. I didn’t mess with the oem links so I could put everything back to oem specs.
with aftermarket lowering links it took me forever to get all 4 corners how I wanted it. You mess with one side, another side goes up or down. Also don’t go super low because at highway speeds the car will lower itself more & cause you to bottem out. After spending two days messing with the height I ended up putting it back to stock. I’ll just leave the lowering to coil overs or aftermarket bags.
1WILLY1
02-23-23 10:45 PM
waijai
06-30-12 10:34 PM
brianlin87
12-01-10 09:03 PM
