Wire came out the pigtail..fml any info would help
I has doing my water pump and i moved the harness to the side after that my car got a vsc light and it went into limp mode ..so i noticed the green wire wasnt plugged into connector anymore..any tricks or info on how to repair ? Lexus doesnt sell the pigtail to splice it
Did the wire strands pull out of the terminal crimp, or did the terminal release from the connector? If the latter, unplug the connector and push the terminal back into place. It has a tiny tang that can be bent up so it locks more securely.
If the wire pulled out of the terminal crimp, have to release the terminal from the connector, open the crimp fold up a bit, then re-crimp and reinstall the terminal in the connector.
