Buying advice : 2007 LS 460 with 140k Miles
Old 01-28-19, 03:37 PM
tinisha
tinisha's Avatar
According to the seller this is what has been done so far,
replaced the valve cover gasket, spark plugs, and gaskets for the spark plugs and fuel pump on 6/21/2018
On 6/23/2017 front and rear rotors and brakes replaced
Replaced the front upper and lower control arms on 6/7/2017 at 116,559.
Old 01-28-19, 04:25 PM
DedBirdDog
DedBirdDog's Avatar
With no air suspension, and control arms replaced (ask to see receipts, your only big issue is the brake actuator. That's a roughly $2000 repair expense that you'll likely be dealing with at some point. If the car otherwise checks out, I still think my original numbers above is where you'd want to be.
Old 01-28-19, 04:41 PM
tinisha
tinisha's Avatar
Although the front control arms have been replaced, the rear ones are not. How much does it cost to replace the rear control arms?
Old 01-28-19, 04:46 PM
joedaddy1
joedaddy1's Avatar
Originally Posted by JLAWS
I don't see much replaced on the service history. I do see the Nav update.
You'd potentially be inheriting a money pit. Get it inspected.
I don't see follow replaced
Radiator
water pump
Serpentine belt tensioner
truck lock motor
control arms ( it was recommended, not sure if it was actually replaced)
shocks
Brake actuator
I could see someone spending $5000 at the dealer just to straighten it out
ehhhh.. most of us don't get the high-priced items replaced at the dealer, so the online service records are almost as good as a Carfax report.
I usually buy factory parts and get it repaired at a Lexus/Toyota specialist.
Old 01-28-19, 07:47 PM
Nospinzone
Nospinzone's Avatar
Originally Posted by tinisha
I thought the Ultra Luxury Package has radar cruise control and Pre-Collision, but this one doesn't have. Correct me if I am wrong!
In 2007 the Pre-Collision Package (which included radar cruise control) was a separate option. Program cars sent to dealers anywhere near the snowbelt did not receive this option. I had to special order my car in order to get it.
There were 3 recalls for this model year. Check the Lexus records to see that they were done. I have 130,000 miles on my car. The upper control arms were done. I have had no issues with the brake actuator, radiator or water pump, or anything else mechanical. The only issues I've had with the car are cosmetic. The wheels are delaminating and the wrap on the drip moldings is peeling.
$225 is not unreasonable for a PPI.
Old 01-28-19, 09:54 PM
tinisha
tinisha's Avatar
I ran a carfax report, No accident and looks good, but there’s no record since 08/23/17. Last reported record for emission inspection at 121361miles on 08/23/17. Is that common?
Old 01-28-19, 10:20 PM
DedBirdDog
DedBirdDog's Avatar
Carfax is dodgy at best. You are FAR better off registering for a free account on the Lexus Driver's Site and looking at what the service history actually is.
https://drivers.lexus.com/lexusdrivers/
Dubbayoo (03-27-19)
Old 01-29-19, 02:11 AM
IMXCITD
IMXCITD's Avatar
I commented in your 430 thread....car looks very clean and priced decent. As others have said....brake actuator and control arms are big ticket items......I'd try to get him down on price as the rear control arms and brake actuators will need to be done. An inspection is money well spent. You can buy parts yourself and find somebody to install. Check brakes, tires and battery....when last changed? 2 key fobs/keys? I'd offer 8-8500.
Old 01-29-19, 05:10 AM
comotiger
comotiger's Avatar
From personal experience, I know that the service history on the Lexus site will only report any work done at Lexus, and in some cases, Toyota dealerships whose computer systems are compatible with the Lexus system. Any work done at a chain store or independent mechanic will not be reported, unless the owner takes the time to manually enter the service into the database on the Lexus Driver site. I agree that Carfax is not comprehensive or reliable. One should check Autocheck also. I have seen accidents reported on Autocheck that don't show up on Carfax.
Old 01-29-19, 08:20 PM
Jasoneo5
Jasoneo5's Avatar
Looks like he had the upper and lower front control arms replaced.
At the end of the day, I think 8,500 is a good deal but I'd see if he'd take 8. You'll probably be able to get the dashboard taken care of at Lexus for free - there are plenty of other threads on that.
Old 01-29-19, 08:43 PM
tinisha
tinisha's Avatar
Ok I saw the car today. It very well shows the cosmetic blemishes of a 11yr old car. Front bumper got paint chips everywhere. scuffs and minor scratches all around the car. Small dent on the driver door. Dash is kinda sticky and the part above the instrument cluster is chipped, damaged panel on the center pillar, passenger seat has a small tear.
It drives pretty smooth no noise what so ever. Played with all the switches. Looks like everything works as expected.
He came down on the price to 8.5k
He gave me the summery of the service he has done so far and also the receipt for replacing the control arms. I am a little confused looking at it. I’m attaching the receipt , Do you guys think he replaced both rear and front control arms or just the front ones.
Thanks a a lot guys
is there anyway I can replace this? Is it expensive?
Old 01-29-19, 08:48 PM
tinisha
tinisha's Avatar
I was reading some threads about the LS dashboard problem. Apparently only few got the dash replaced. it seems you should have contacted Lexus within the 10yr period to have Lexus replaced the dashboard.
Thanks!
Old 01-29-19, 09:13 PM
joedaddy1
joedaddy1's Avatar
the dashboard will probably be replaced by the dealer for free, the warranty extension is to 2021 now (includes dash, door panels, glovebox, rear bottom of armrest, etc)
if he got the control arms replaced at the dealer, that's a MEGA PLUS..
Seems like a good car $9k... Remember, this car was $70k+ when new. Just be prepared for typical repairs needed for a 10+ year old car.
Good luck!
tinisha (01-30-19)
Old 01-29-19, 09:27 PM
tinisha
tinisha's Avatar
Good luck!
The control arms got replace at a local mechanic with two year warranty, which will expire this June! The rear ones haven't replaced yet .
Old 01-29-19, 09:30 PM
waterdude
waterdude's Avatar
According to the receipt the mechanic used 10W-30 oil instead of 5W-20.
tinisha (01-30-19)
Quick Reply: Buying advice : 2007 LS 460 with 140k Miles
