Fuel injector servicing & Spark plug 2007 LS 460 125000 miles
Hi all , I would LIKE to know p if we should service the fuel injectors and change the spark plugs because my car is running perfectly fine now.
am not sure if i should change the spark plugs and perform fuel injector cleaning at this time. Is it an unnecessary service at this period? Or can i continue with normal oil change service..my car has cuurently clocked 126000 miles.it is a US spec car in Dubai. The brakings are all fine now. I have never changed the spark plugs or performed fuel injector services and also the tranny fluid
Need your suggestions.
I would have the plugs changed, they're due. If you are using Shell premium gasoline, I would skip the fuel injector cleaner. If the transmission hasn't been serviced before, I wouldn't touch it now.
Plug change at 70k and top tier heavy detergent Costco/Union Oil gas and a trans flush made the car totally smooth and you can barely feel it shift.
would do all three in a heart beat. Driving agressively runs the detergent in the gas through both injector circuits.
took 20k miles in total. Hesitation slowly faded. Now gone.
previous owner had had it cleaned. Still hesitated. Switch gas. Drive it hard, plugs. Gone
ALK (01-31-19)
BinaryJay
10-12-21 08:17 PM
