Techstream
#91
Do you know of an alternate link to obtain a v12.30?
Good news! The 2.0.4 firmware works with version V12.30 for 2013 LS. I was able to access the data list for the engine ecu without any crashes.
I tried to run V13.0 but it kept crashing so I went back to V12.30, and it worked flawlessly. I also tried with the V13.30 through virtual machine but I couldn't get the cable to connect to the VIM.
I would like to load it to W10 64 bits and cable 2.0.4 from AliExpress soon...
Thank you in advance!
-Dennis
ducpho10@yahoo.com
#92
Try this one.
http://blog.obdii365.com/2017/12/03/...d-and-install/
Also read through this thread and you will learn all you need to know about installing Techstream. The best peace of advise is get a old 32 bit Windows XP laptop.
Tech Stream Software Cable ver 2.0.4 - ClubLexus - Lexus Forum Discussion
#93
For anybody that wants to get Techstream up and running, this video is good:
It has a guide for running Windows XP 32-bit as a virtual machine on your laptop via an OVA template. Don't worry, it is incredibly easy.
The video description contains links to everything you need, but I've reproduced the OVA link here.
OVA Windows 32-bit template including everything you need.
- Windows / Intel Mac: LINK
- M1/M2 Mac: LINK
I used this cable:
Color: FT232RL
https://www.aliexpress.us/item/672381461.html
- M1/M2 Mac: LINK
I used this cable:
Color: FT232RL
#94
Techstream / Wireless Code Resgistration Utility
I have a 2014 Lexus IS 250 and am trying to connect to the "Wireless Code Registration" utility to reprogram my FOBs to open the keyless entry. I've reviewed multiple posts and this option is supposed to be available under "Main" / "Utility" but I am not able to see "Wireless Code Registration" or "Wireless Code Erasure" as in the image below. I can successfully see the Customization, Initialization and Diagnosis Mode screens but I'm wondering why the other two options don't exist.
At first I thought it was this bug in Techstream version 18 but I have also tried TS V17, V16 and all the way back to Techstream V12.20.024 but none of them are showing this option for my Lexus IS250 ECU. I've tried it with the driver door open and closed, doesn't make a difference.
Anybody know if there is a specific sequence that needs to be run in order to make this option available?
#95
You are better off asking in the IS forum. I would guess, your car just does not have such option.
CareyPJ
12-22-22 10:30 PM
