LS460 vs LS500 vs G90 vs Continental...
I suspect it may have to do with the overall higher cost of living out there. As an experiment, I ran MMR on the same 2015 LS460 witth 31k miles, non adjusted CR and white color. See the following:
National MMR is $35,500
Southeast - $35,710
Northeast - $35,300
Midwest - $35,100
Southwest - $34,800
West Coast - $36,100
For those of you looking at traveling to buy cars, this is definitely something to consider.
mckellyb (12-08-19)
People had to overcome that with Toyota too though, it will come in time.
I thought My grom vline2 allows me to have car play?
A Mercedes S class is a aspirational car for many because of how nice it is, not necessarily just because it is a Mercedes. I like the S class but a CLA, GLE, C class does absolutely nothing for me, I don't care if they are Mercedes, I would much rather have a GS, G80, LS460, or G90 over those cars.
I know many people who aspire to own a Lexus. But, that has come about over the 30 years Lexus has existed, it will take time for Genesis to get there.
1) LOVED the car for a while. Ballsy V8 with solid interior (not LS level, though) and incredible Lexicon sound system (Much better than LS's).
2) Was reliable until 2017 when the ABS Controller/pump went out. Recall issue so replaced it after much harassment.
3) Late 2017 Valve spring broke in Cycl 4. Caused BAD vibration. Dealer could diagnose. Did plugs/wires, then wanted to do computer. Took to great indy and diagnosed spring in 2 hours... replaced without pulling head (dealer mandates pulling head)
4) Therm went out in late 2018.
5) ABS ECU Went out again in early 2018 just outside 1yr warranty. $2k repair. Indy couldn't get pump to program to Computer. Had to take to dealer.
6) After return from dealer it had huge electrical issues... radio wouldn't turn off (killed battery), wouldn't recognize key, etc. Left with dealer for 3mo (thankfully had LS at this point) and they gave up.
7) Pulled fuse to mask issue and dumped at Carmax for $5k
Dealership/Service at Lexus is literally orders of magnitude better than Hyundai. Don't forget to factor that in.
LVPUNK (09-22-22)
That car and Genesis today are a totally different world.
As for service, remember with a new Genesis service is included for 3 years, and they pick up and drop off the car so you never have to go to a dealership. We have a few owners here and everybody I've talked to have been very happy with the service.
No matter what Hyundai promises on a corporate level, you will be stuck interacting with your local dealer... Keep that in mind and look into the service department's rep before making that commitment. YMMV.
I still like to keep up on the Genesis G90 Forum, and I saw this post today (see below). I thought it illustrated some of the frustrations the G90 owners are having with the dealership service. And yes, as Steve pointed out, the dealer will come pick up the car and bring it back when done (Concierge Service), but if the service work itself is crap, the nice delivery service won't make up much good will...
_________________________________________________________________
First trip from Arizona to North Carolina. New car almost no miles on it. First time car was over 70 miles per hour.
Side wall blows out from tear on inside of bead area. Wife and 2 grand children in car. Genesis couldn't find a tire near by
Finally located a off brand tire 2 hours away and on the donut under 50mph. Was over 3000 miles back home where it took me 3 days to get the right tire. Had to pay for it my self, Reimbursed later by Genesis. Tire company said have dealership call and they would approve a new tire. Dealership said they don't do that.
shortly after returning air bags shut down. Dealer said they repaired.
Next trip Air bags shut down after 200 miles into trip. traveled al the way to North Carolina before anyone could fix.
500 miles coming back air bags out again. Left car with dealer upon arriving home and took a dealer rep to get it fixed.
Then as starting a trip anti freeze is low. dealer topped off then on starting trip, no heat. At dealership for a week because they
couldn't figure out what was wrong. Even with a TSB being out on problem. Took a week to get part.
Asked about my map update was told there wasn't one. After showing Genesis there was one, They updated map to version 12 and not 12.5
I just stopped taking car on trips and that was what I purchased car for. It is the ultimate with monitors in rear for great grand children.
Don't worry about if I'm stuck on road but grand children and great grand children it is a different story.
Not going to get into all the little things that have gone wrong
Dealer quality varies, it does with Lexus too. On a trip like that not being able to locate the proper sized tire within a certain radius is a common problem when cars run low profile high performance tires. If you're out in the middle of the country in an LS and you experienced the same tire failure, you would have a similar problem.
The other issue items are a different story. The question would be how common are those issues? The G90 scores extremely high in initial quality (higher than the LS)
It's always YMMV. For example, read through the service history of this 2016 LS460. It goes through the auction in New York Thursday. JTHDL1EF3G5007905. Nothing like brake actuator problems at 10k miles. And that's just the tip of the iceberg with that car. It just happens.
