Headlight Assembly Reinforcement
I have a 2007 LS 460 that is missing the small chrome strip that fits in the bottom front of the right headlight. It appears to be a cosmetic part and I think it is called a "Headlight Assembly Reinforcement". There is also a gasket that fits under this piece. My question is am I naming this part correctly so that I can order the correct replacement part. Thanks
I believe the strip that you are mentioning also contains the equipment for the headlight washer. Mine disappeared as well sometime ago and I had no luck finding it anywhere. Later I found one in a junkyard from a wrecked LS460. When I was on the quest to find it, I was naming it 'Headlight Washer'. Its the silver little thing and its job is to pop out and spray the washer fluid with pressure to remove any dirt from the headlight, anytime when you engage the windshield washer and the headlights are turned on.
Good luck and hope this helps!
https://www.ebay.com/i/272697971339?chn=ps
