Why does the LS disable VSC, ABS, PCS every time something goes wrong?
I absolutely love my 2007 460L Ultra Luxury, but it's driving me a little crazy with disabling all of the car's safety system every time something goes a little astray. In the past 2 months I've had 2 O2 sensors go bad and today my AFS went a little haywire - each time causing all of those safety systems to go down. Can anyone explain to me why the LS needs to turn off VSC, ABS, traction control, and PCS every time I get a CEL or some other kind of error? Today I drove for an hour in 4 inches of snow with everything disabled. Brought me back to my teenage years of driving a rear wheel drive car - it was quite an experience.
On a side note - the AFS error went away and all my systems were back in working order after I was home for about an hour and went back out. Hoping it was just a one time fluke thing (The AFS flashed immediately after hitting a pothole on my passenger front side - then all of the other systems disabled themselves within a few seconds of the AFS error).
I'm mainly interested in why everything shuts down when the adaptive headlights indicate they might have a problem, or an O2 sensor isn't working like it should. Seems crazy to shut off safety systems for very minor non-related (at least according to what I understand) issues.
I had the same issue with the pothole I posted a thread about it, I had to use a odb reader and Clarista, cleared the codes and no problem since, but no one has really commented anything else so I don’t know much about what happened.
Did the pothole damage any wheels. Maybe the wheel speed sensor was damaged when you hit the pothole, hence it throwing the code.
I don't think those lights are an indication that the systems have been turned off. Instead it is an indication that the systems have been trigged because an instability has been detected. The lights are a latched indication that the systems were triggered, to make you aware that conditions may be unsafe and, as "Little" suggested, will be reset when the ignition is cycled.
Thanks for the input. I know that the Cruise is disabled. Since I have very little experience driving in snow I wasn't aware that you could sense that the VSC was disabled - I thought stability would be uncertain with or without VSC.
