car audio question
car audio question
About how many feet of power cable would i need to run from the battery to the trunk? i will be using 0 gauge.
I recently removed my amp rack and custom sub enclosure from my 2009 LS because I was selling it. I just measured the 0 awg I removed and it was about 12.5 ft long. I have put my custom made enclosure on ebay for sell if you want to take a look at my pictures to see my sub enclosure and amp rack. Just search for "Lexus LS 460 custom subwoofer enclosure" on ebay if you want to find it.
ALK (02-27-19)
Thank you! I looked up your listing, but cant find it. What subs where they made for?
I have attached pics.The sub is a single Image Dynamics 12. The enclosure was built into the right cubby area.The Amp rack housed 3 JL Audio amps and took up very little space. The power wire was wired to the back (facing the rear seat) of the amp rack to a distribution fuse block that as accessible via the rear seat pass through. When the armrest was down it revealed the fuse block. The entire system was very stealth and sounded great. I used the Rockford Fosgate 3 sixty.3 processor to connect it to the factory head unit.
mambo619 (02-19-19)
thank you. ill look into it and that sub. Looks awesome BTW
for future reference, 15 feet was enough to run from the battery (through the passenger side) and to the trunk, behind the rear seats. this is for 1 amp. The AMP kit i bought had 18 feet. the remaining 3 will be used for a 2nd amp for the highs. i used the Stinger SK6201 Amp kit. it is really flexible and easy to use. I would recommend it.
beejaydee8
01-30-14 06:00 AM
charmz
06-26-08 07:10 AM
