2010 LS460 Over heating
Did you check the coolant level?
Also, check the radiator, make sure a plastic bag or something hasn't gotten stuck to it.
Once you get past that, I don't know...thermostat, maybe?
Have you verified that the car is actually overheating or are you just basing it off the temperature gauge in the car? the reason why I ask this is because my 2011 had a bad heater exchange plate which caused the car to go up all the way to hot but it wasn't actually overheating. Total to replace at dealer would have been $1548 without warranty and it included replacing heater exchange plate, intake gasket, throttle body gasket, and o-rings.
Regarding leaky water pumps - Very possible. My water pump was weeping out the bottom hole very slightly (about 83K miles). Over a 6 month period my coolant level dropped about 1.5" in reservior. I tool an inspection mirror and flashlight and seen alot of dry crusty pink residue on bottom of water pump - note, never seen a drop on garage floor. So, eBay special water pump and fresh coolant and now 104K miles and still going good.
LS 460 valley plate coolant leak
Water pump leaking at 83,000 miles on a nine year old car is something I'd definitely consider being the problem. Get a flashlight and look for pink crusty staining around the water pump. Be very careful leaning over the radiator, there is a coolant bypass nipple that is plastic and EASILY breakable on the coolant reservoir.
virulosity
IS F (2008-2014)
50
10-13-16 09:56 AM
I8ABMR
IS F (2008-2014)
11-24-14 10:09 AM
