Brake Bleed Question?
So I have a really dumb question for those who have bled their own brakes on their LS460. So was reading the workshop manuals to determine any gotchas, and OMG did I find them... https://workshop-manuals.com/lexus/l...rake_actuator/
I'm used to the one person method of turkey baster the reservoir, filling the reservoir with new fluid, tube on RR brake nipple into bottle with some fluid, then steady pump of brakes until fluid runs clear. If all I'm doing is running new fluid through the brake lines, then is the overly complicated procedure mentioned in the workshop manuals really necessary? I'm not trying to clear air, replace an actuator, master cylinder, etc... I just want to get new fluid in.
Please advise my risk
As much of a staunch DIY'er that I am, even I gave this job to my local Toyota dealer. They even had to do it twice because of a brake code that was triggered. It's a very exact job and requires Techstream. What would normally be a one hour job, ended in being two hours. They charged me 79.99, so for that price it's a no-brainer.
use this info. files and follow the steps
Tlutrick (03-14-19)
We change the rotors and pads on my 2013 ls460 f sport with slotted and drilled rotors. My friend accidentally took the wrong bolt out and fluids was everywhere. The brake light, traction control and ABS light came on. Took it to the dealer and they charged me 325. Took them 4 hrs to do it. They gave me a loaner car to drive home. Went to pick up the car the next day. These cars are so complicated if you messed up. It's not like the older cars.
I was aware of the techstream procedure but to be honest I ended up using the motive power bleeder and everything went perfectly fine:
You just need to make sure to use the adapter in the video (expensive but worth it), take the time to make sure your seals don't leak and above all don't introduce air bubble in the system.
So I went out to... https://workshop-manuals.com/lexus/
Printed my own from the screen shots to make the following pdf's (apologies on the image quality for Brake Bleed Techstream compressed file, but the forum prohibits greater than 5Mb files, so I had to compress the image quality), which are descriptive of the Techstream screens. You can go out and see the procedure in better quality at... https://workshop-manuals.com/lexus/l...rake_actuator/
I've gotten by for awhile with my Innova 3100j scan tool, but this forced me to pull the trigger on Techstream, Cable, and a $199 Windows 10 64 bit laptop off of Amazon.
The ambiguity of NOT performing the accumulator zero down function in this Techstream process worries me just enough to make me feel uncomfortable using a typical 1-man method or Pressurized system.
You don't have any repair shops close?? You have a toyota shop closer? Most normal repair shops should be able to handle it ask around. Cost wise i think is anywhere around 80-150.
Unless you are replacing your brake actuator, you should select "Usual Air Bleeding" instead of "Actuator has been removed" on Techstream to conduct the rear brake bleeding (Page 13 of your file "Brake Bleed TechStream"). The verbal description of the bleeding process with TechStream sounds complex but the actual process is straightforward. The instruction of selecting "Actuator has been removed" option in your file (Page 13) was meant as an attempt to repair the first generation of brake actuators on 2007-09 LS460 before the dealer calls for the replacement of the actuator under warranty (i.e., an extra step required by Lexus to validate a request for replacement of the brake actuator under warranty).
Tlutrick (03-15-19)
I was aware of the techstream procedure but to be honest I ended up using the motive power bleeder and everything went perfectly fine: https://www.youtube.com/watch?v=xAK_nuBkxz0
derpie (04-07-19)
That is helpful, so thanks for clearing that up Zeroing the Accumulator. I have already ordered a new $199 Windows 10 Laptop and Techstream cable, as I keep running into need for TechStream, but my cable won't arrive until Tuesday, 3/19. How critical is the step regarding the directions to Disable Brake Control (Step 1a on Bleed 1.pdf)? If critical, then I will attempt to do with my Innova 3100j scan tool. If it can't handle that operation, then I guess I will wait until next week to set up and verify Techstream is working.
1) If your new $199 Windows 10 is 64-bit (the default with new Windows 10 laptop and desktop computers today), the success of your installation of TechStream depends on the TechStream software package you purchased and USB cable type, that is, you'll need the 64-bit driver for the 64-bit Windows OS to communicate with the ODB cable/connector properly. Hope that your Techstream seller included the 64-bit driver in the software package.
2) "Disable Brake Control" step (I took it to mean the "Zero Down Accumulator Pressure" and "ECB Invalid" procedures in TechStream terms) is necessary for properly bleeding the front brakes. The "Zero Down" procedure releases the pressure in the accumulator and the "ECB Invalid" procedure allows you to do the front brake bleeding manually (the traditional two-person bleeding process). Don't skip these two procedures. Follow the instructions and steps in your document "Break Bleed TechStream_compressed small.PDF" file to complete the front brake bleeding.
3) TechStream is the right tool to use for LS460 brake bleeding. Since you will have TechStream, no need to use Innova 3100. My recommendation is that use the right tool (TechSream) that Lexus/Toyota technicians use to do brake bleeding - do it right and do it once.
4) Just a word of encouragement. Bleeding with TechStream is not difficult or complex. Just follow the instruction in your "Break Bleed TechStream_compressed small.PDF" file and follow the instruction on TechStream screen, you'll get it done. Be patient with TechStream and with the bleeding process. Make sure that your car's battery is fully charged before you begin to bleed the brakes. I learned my lesson the hard way. My car's battery was drained during the bleeding process as TechStream used quite a bit of battery. That created a small crisis but was easily resolved once I replaced the battery and used TechStream to reset the brakes.
For replacing the brake fluid . The "Usual air bleeding" is the step . But you must keep the level above low . Don't go below low as that would result in air in the system . I have did it to my LS 460 and 2 other LS 460 . And make sure the car is level .
