600H LED Headlights
Does anyone know if you can retrofit the LED headlamps from a 2008 600h on to a 2008 460se-l ?
I have a similar question for the LED headlights on the 2013+ LS' to see if they can fit on the 2013+ LS' that have normal HIDs headlights.
Obviously you need new ballast etc etc, but I wonder if the headlights themselves bolt up without issue.
There was a few threads about this. It's not a direct fit as I remember. I think you need the whole front end because they are shaped different than the LS460 / L models.
Someone can correct me if I am wrong but, 95% sure on this... I THOUGHT about this one too
kenmac21 (03-17-19)
07-09 is a direct swap but you need the special harness to get them to work. There are some places on Buyee and Yahoo Auctions that sell the harness. Might also be available here in the US from independent sources. Last I recall it was about $200 for the harness. You also need to make sure the 600 headlights havent been gutted and have all their motors/actuators along with computer modules.
