Brakes Squeal when backing up
Old 03-15-19, 09:40 AM
P460lawd
P460lawd's Avatar
Default Brakes Squeal when backing up
I have a 2012 LS 460L AWD. Changed the brake pads and used the E-brake for the first time. When I finished, I clicked the E-brake off and now the brakes squeal every time my wife backs car up - no squealing in forward. I'm assuming E-brakes hung up, but I guess I'm not sure why? I don't feel like removing the rotar to inspect as the car only has 45,000 miles, so the E-brakes should not be too used. Can I adjust the E-brakes without removing the rotar. Also, wondering why it only squeals in revers. Thanks for any advice.
Old 03-15-19, 10:33 AM
prichmon
prichmon's Avatar
Yes. At least on my 07 you can.
Pull the wheel
There should be 10 holes.
5 are studs and 5 others.
While turning the rotor at the 9 o'clock position there will be an opening.
In other words as you roll the rotor around 1 of the odd 5 holes holes will align with a hole in the bearing flange.
Use an ~1/4-5/16" screwdriver to adjust the brakes.
Look up rear e-brake replacement.
Rich
Old 03-15-19, 12:34 PM
P460lawd
P460lawd's Avatar
Thank you. I guess I'm still curious why it is squealing when backing up. I would think if the E brakes were tight on the rotor they would squeal in both directions?
ISFCOBRA
IS F (2008-2014)
03-16-15 08:38 PM
bigblack06
05-13-14 01:38 PM
gabzor
13
03-31-13 08:27 PM
nmpeter
Suspension and Brakes
03-05-12 10:05 AM
humbleto
01-28-07 08:02 AM
Quick Reply: Brakes Squeal when backing up
