Center dash speaker blown
My center dash speaker started rattling like crazy in my 2007 LS w/ML system. I plan on replacing it with an OEM speaker, possibly used. Does anyone know the part number? Also, I searched the forums but couldn’t find info on how to remove the speaker. Any instructions available?
For an ES model but probably the same method.
https://www.clublexus.com/forums/es-...placement.html
For a GS model with great pics. Same as ES model, so LS most likely the same. Scroll to post #36
https://www.clublexus.com/forums/gs-...aker-ml-3.html
Here is some information regarding your speaker project. The Removal instructions refer to disconnecting
the 12v battery but I have never done that for a simple speaker exchange, just be sure the radio is off, right?
Hi.....is it the Middle dash Speaker? Am not sure if we have remove the complete .Dash board and reinstall the speaker .
I think...if we want to replace any of the 3 speakers in dashboard...we moght have to remove thw entire dashboard out ...pls cross check.
Because i have tried once to install front right dasjboard speaker..but could not do it from the garage as they told we have to remove the entire dashboard out to check the speaker
Thanks
Thanks
sallensr
07-10-15 10:16 PM
