Spark plug tube seal replacement?
both sides are leaking, especially all the corners. I wonder if I somehow damaged the corners trying to remove and install the covers. They were a pain to remove and install because of the angle they sit in. Those long bolts that stick out from the fuel pump were in the way and I kept trying to find a way to slide the covers back to the original sitting. Maybe I bumped them to much.
i think those metal tubes might need to be pulled up and resealed from the bottom. That is where the oil is probably coming from.
any help would be appreciated.
I am certain this was the issue, you may need to try the repair over, with more care?
I’m just surprised that for a lexus it’s been nothing but issues.
I am certain the last thing you want to do is perform the service again!
But you have to to fix the issue!
You messed something up!
Grab a **** Creek and tackle it this weekend!
Many times I have had to step back, think..................and it all came together!
elejes (04-29-19)
The tube seal is 2 pieces. You can pull the harder plastic inner ring out of the outer softer rubber. If you do not push the inner seal down to the top of the metal tube you can get oil into the metal tube.
The inner piece comes out which allows more room for the removal of the coil pack and plug boot.
I purchased my parts from rock auto valve cover gasket set with seals.
1st time I pulled the valve covers.
2nd one I did the following:
If you look closely at the valvecover there are a couple small reliefs of each side around the seal. I used a small pry bar and gently lifted the tube seals out without pulling the valvecover.
I also used a little rtv around the metal portion which seals to the valvecover to make sure I did not have any repeat leaks.
Good luck.
Good luck.
Good luck.
Good luck.
