Spark plug tube seal replacement?
Anyone ever had the problem of oil getting into the spark plug metal tubes even after replacing the valve cover gaskets, and top spark plug seal? I’m thinking mine are leaking oil from underneath the metal tubes.
does anyone know how to fix it?
Im starting to regret buying this vehicle.
Part # 11193-38020 . GASKET, SPARK PLUG TUBE
I would do plugs seals and VC gasket while you are in to it!
Good luck!
https://www.lexuspartsnow.com/parts/...del=&Filter=()
i had that exact part replaced when they opened it up to do the 3 recalls. I am only paying for parts. All rubber parts degrade over time
